Go Back   Nitto 1320 Legends Community > Nitto 1320 Legends Car Forums > Dyno & Tuning
Old 06-22-2012, 05:25 AM   #1
gareth
Default 18 steps for making a cheap brkt setup suited to ur pc specs brought to u by gareth
Hello fellow nitto players,
I have made this guide because alot of my friends have asked me how do i make my own brkt setups and I say simple but I didnt have this guide to hand as lost the original one I made, so I decided to remake it post it up for everyone to see was probably gonna be easier than telling like 6 or more friends these steps over and over again.I did get some input from Xtremedarkness as he remembered some of the points i may had forgotten. I also made this guide so that new nitto players who cant afford high end expensive brkt setups can still get a brkt car that runs good and is tuned to their pc.
I hope that this helps out ppl and i hope to see u in the future on the drag strip in game.
how to make a cheap brkt setup
step one: choose the car that u want to setup for bracket
step two: part1: check redline of the car using practice track
part2: check if there is any engine swaps but this is for all cars so u dont have to have engine swap in the car
step three: choose either laces or 20 inch points rims or rims that hold revs to 5k
step four: buy drag slicks u can use 555r tires but i find slicks easier
step five: part 1:goto parts shop and buy the formuline air fuel controller
part 2: only get boost controller if u plan to have stock turbo or supercharger attached
part 3: only get headers if u have a stock turboed car and u want to make it naturally aspirated
step six: goto gearbox section in parts shop and start with 2.500 first and final
step 7: if u can afford to get a body kit for the car
step 8: goto dyno n run the dyno at last red dot
step 9: go back to practice track to see if the car launches (if redline is like 6k on vehicle then hold revs at 4.5k otherwise full rev)
step 10: take a note of the time ran
step 11: start to make slight modifications to the ratios by raisin the final drive number then test again
step 12: start with small mods like low compression pistons and maybe air filter then test again in practice track
step13: if u prefer to run fluids add fluids and radiator but most my car dont use em
step 14: hit practice track again if it running faster than what u want it to run try modifying the ratios or taking a fluid part out (if u have fluids)
step 15: hit the PT again after u have completed step 14 and if u are happy with the time then run PT 5 times to make sure u have dial in
step 16: either ask a buddy or race ppl u know u can beat as a test live or if u dont want to do that hit 24/7 tournaments
step 17 : if everything goes to plan u should have a pretty decent setup made for next to nothing and u can go live and start racing ppl in brkt
step 18: if u want to paint ur car or put graphics on it then its ur choice
note i use this method on all my cars because i dont run an intel pc like most nitto plus this method has worked on all pc bases.
The vehicle i based this on was a k24 Type-r.
gareth is offline   Reply With Quote
Old 06-22-2012, 05:42 AM   #2
xtremedarkness
Send a message via Skype™ to xtremedarkness
Nice post man hope this helps all the new players out there
__________________
Guided: 15/06/12
Modded: 28/02/13
GOT A PROBLEM REPORT IT HERE
http://nittolegends.com/support_default.aspx
Alright alright we go live in 5 for some Straight up Automobile Pimpin
Run with it or Run from it.
T1 Beby
2442
-Matt
xtremedarkness is offline   Reply With Quote
Old 06-22-2012, 08:09 AM   #3
boxxi
Unconfirmed
i should release my 11.533 m6 setup
boxxi is offline   Reply With Quote
Old 06-22-2012, 11:19 AM   #4
HaTerZ NaTioN
Extremely poor quality. A+ for idea/concept. F- for execution.
HaTerZ NaTioN is offline   Reply With Quote
Old 06-22-2012, 11:58 AM   #5
KamaroGuy
How about you contribute something positive to the thread than be a troll.. Let's see you create a better thead that is as helpful as this. This will be a very good start for new players.
Great job.
KamaroGuy is offline   Reply With Quote
Old 06-22-2012, 03:45 PM   #6
xtremedarkness
Great job.
+1 also gazza worked on that for a long time if even you dont use this thread as guide theres heaps out there
__________________
Guided: 15/06/12
Modded: 28/02/13
T1 Beby
2442
-Matt
Old 06-22-2012, 11:26 AM   #7
TheSages
Default I fixed it for you.
Originally Posted by gareth View Post
How to make a cheap bracket setup:
Step 1: Choose the car that you want to setup for bracket.
Step 2:
Part 1: Check the redline of the car using practice track.
Part 2: Check if there is any engine swaps, but this is for all cars so you don't have to have a engine swap in the car.
Step 3: Choose either laces or 20 inch points rims or rims that hold revs to 5k.
Step 4: Buy drag slicks, or you can use 555r tires, but I find slicks are better.
Step 5:
Part 1: Go to the parts shop and buy the formuline air fuel controller.
Part 2: Only get boost controller if you plan to have a stock turbo or supercharger attached.
Part 3: Only get headers if you have a stock turboed car and you want to make it naturally aspirated.
Step 6: Go to the gearbox section in the parts shop and start with 2.500 first and final.
Step 7: If you would like to buy a bodykit, then get one.
Step 8: Go to the Dyno and run the dyno at last red dot.
Step 9: Go back to practice track to see if the car launches (if redline is like 6k on vehicle then hold revs at 4.5k otherwise full rev).
Step 10: Take a note of the time ran
Step 11: Start to make slight modifications to the ratios by raising or lowering the final drive number then test again.
Step 12: Start with small modifications like low compression pistons and maybe air filter then test again in practice track.
Step 13: Hit the Practice Track again if it isn't running faster than what you want it to run. Try modifying the ratios.
Step 14: Hit the Practice Track again after you have completed step 13 and if you are happy with the time then run PT 5 times to make sure you have the dial-in.
Step 16: Either ask a buddy or you can race people you know you can beat as a test live.
If everything goes to plan you should have a pretty decent setup made for next to nothing and you can go live and start racing people in bracket.
I corrected the grammar and such. Replace your post with this one.
I also reduced the steps down to 16 steps.
TheSages is offline   Reply With Quote
Old 01-05-2013, 09:12 PM   #8
crxgod 3
I reduced it down to two
crxgod 3 is offline   Reply With Quote
Old 01-05-2013, 10:13 PM   #9
MIVEC TUNER
Nice and good info ty
MIVEC TUNER is offline   Reply With Quote
