Prev Previous Post   Next Post Next
Old 07-01-2012, 03:52 PM   #1
1 0 1
Default All you need H2H setups
To find the car setup you are looking for, press "Ctrl + G" and type the car you are looking for!
If you didn't find the setup you were looking for while using ctrl + g, go to the next page and try again.
__________________________________________________ ________________________________
Engine: K20
Toreno
Newburge
Creek Side
Vista
Diamond Point
5.200
2.500
1.600
1.095
0.793
0.572
6.330
Ichiban Drag Launch Kit
Nitto NT05
Volk Racing TE37 White 17"
OEM Cylinder Head Assembly
X Motorsports Lightweight Axle Set
Axe Racing Titan Cam Gears
Takayami T472 Down Pipe
Blowfish R II Piping
Blowfish E65 Turbo Exhaust Manifold
BigBoss Ball Bearing 42 PSI Turbo
Gugem Racing Head Gasket
Kobi 8:1 Racing Pistons
Taxidy Valve Springs and Titanium Retainers
Gugem Competition Pipe 100mm
Gugem Racing Muffler 100mm
Yukomi Ultra Exhaust Piping 100mm
Gugem Competition Fuel Rail
Gugem Competition Fuel Pump
Motiv Arctic Intake 4.25"
FastFlow Cone Air Filter
Tokiya Pro-2 Cams
Flospeed Billet Racing Throttle Body
BigBoss Blue Cables
Blowfish B series B.O.V.
DataPro Pro ECU
Takayami Full Race Cylinder Block
Motiv Ultra-Light Flywheel
Gasman G100 Fuel Pressure Regulator
Techoline R2 Oil Cooler
Formuline 250 Shot Nitrous Jets
Gugem Competition Fuel Cooler
Formuline Single 10lb Carbon Fiber Bottles
Taxidy Max-Light Connecting Rods
DaBest Signature Series XL5 Intercooler
FireShield Racing Thermo Wrap
Takayami 1000cc Injector Set
TRM Carbon Fiber Battery
Niome Power Crankshaft
Formuline Air Fuel Meter
Royal Purple Synthetic Lubricant Package
Mishimoto Performance Low Temperature Thermostat
Royal Purple Oil Filter
Mishimoto Liquid Chill Coolant Additive
Mishimoto Performance Aluminum Radiator
Sparco S Light CF Seat
K20A2 (Engine)
Note this setup has 804 hp K20A2 Only!
Driving Instructions
Car:Mitsubishi Lancer Evolution Vlll
Ratios:1st 5.721
2nd 2.589
3rd 1.550
4th 0.999
5th 0.652
FD 5.430
Toreno
Newburge
Creek Side
Vista
DIAMOND POINT
OEM Control Arms
OEM Torsion Bar
RL Design Front Bumper
RL Design Rear Bumper
M Tune Billet Motor Mounts
Factory 21 Sway Bar Set
Volk Racing TE37 White 20"
RL Design Side Skirts
RL Design Carbon Fiber Trunk
Downside Racing Carbon Fiber Hood
Aerosthetic JDM Style Tail Lights
Nitto Invo
Yukomi Turbine Tube
Skoei SportTune Oil Cooler Kit
L2 Lightweight Coilover System
Power Works Nagoya JDM Headlights
Blowfish FI Elite Series Camshafts
Tespo E-95 Fuel Pump
Kosen 8.5mm Spark Plug Cables
X Motorsports Traction Control
MNK Racing 6 Pad Clutch Kit
Formuline Air/Fuel Controller
Hunter Dura-made III Connecting Rods
DataPro ECU Chip Stage III
DaBest Iridium Plugs
Skoei Pro Cam Gears
TRM RS-Ti Titanium Piping 4.25"
J-Tech Tech-80 45 PSI Turbo
Takayami Turbo Exhaust Manifold
Niome Performance Crankshaft
DaBest T51Z Turbo Piping
Takayami Max Flow Air Filter
Breeze Race Series Intake Manifold
Taxidy Pro Valve Sets
Tokiya 120mm Open Race Pipe
Breeze High Flow Intercooler
Power Works Nagoya Performance Sleeve Block
TRM RX Intake 100mm
X Motorsports Xtreme Throttle
X Motorsports Xtreme Cylinder Head
Gasman 250 Shot Fogger
Skoei T5 Head Gasket
Enjin Performance Oil Pump
BigBoss Pro Series Valve Springs
Monarch Drag Muffler 4.25"
Suprec ZS Fuel Rail
4G63 (Engine)
Note:This setup has 775 hp
Driving instruction
Car:Ford Mustang Gt
Ratios
1st-4.792
2nd- 2.259
3rd- 1.250
4th- 0.860
5th- 0.570
Final Drive- 3.799
Toreno
Newburge
Creek Side
Vista
DIAMOND POINT
TORENO
RL Design side skirts
Diabolito open grille
Radiant Compact Fuel Cooler
Techoline Race Fuel Pump
NEWBURGE
OEM Motor Mounts
OEM Antai-sway bars
OEM Clutch
OEM Spark Plug Cables
OEM Front Bumper
OEM Trunk
OEM Headlights
OEM Taillights
Kosen ProFlow Cat. 80mm
SKoei Race Oil Cooler
99H (engine)
CREEKSIDE
Fireshield racing thermo wrap
Autorock 1.5mm head gasket
Kobi spec 1 fuel rail
BigBoss 1080cc Injectors
Blowfish Xtreme 4" Turbo Down Pipe
Blowfish R series Piping
BigBoss +0.1L Block
Kobi Racing Throttle Body
Taxidy T-1 Intake Manifold
VISTA HEAGHTS
X Motorsports Pro Launch
Stealth Low Compression Pistons -2.5:1
Suprec Fang Oil Pump
Taxidy Max Crankshaft
Blowfish E70 Turbo Exhaust Manifold
Beast Performance Monster Head
Blowfish FI Elite Series Intercooler
Axe Racing Pro Cam Gears
Blowfish GR84 22 PSI Turbo
BigBoss Pro Flo Muffler
DaBest Super Filter
Motiv Arctic Intake 4"
Autorock Sports Series Valves
DataPro Pro ECU
Dilat TV8 Performance Rods
Autorock Stage 2 Axles
HRE 441R 17"
-Can be other rim but needs to be 17"
DIAMOND POINT
Formuline Speed III Cams
Formuline 300 Shot Nitrous Jets
Vista/Diamond
This setup has 1130 hp
These are lb ratios for the Fathers Day event rims
4.815
2.223
1.341 4.975
0.858
0.564
Driving instruction
Special thnx to I R34 I
1 0 1 is offline   Reply With Quote
