With this setup I have managed to run 7.045 and 7.054 Live >>>
------------------------------------------------------------------------- Volk Racing TE37 Black 20" X Motorsports X-9 Front Bumper X Motorsports X-9 Rear Bumper X Motorsports X-9 Side Skirts X Motorsports X-9 Carbon Fiber Hood X Motorsports Carbon Fiber Trunk OEM Taillights OEM Anti-sway bars OEM Engine Mounts OEM Control Arms OEM Headlights OEM Torsion Bar OEM Spring & Shock Absorber Set Sparco S Light CF Seat Nitto NT05 Mishimoto Performance Aluminum Radiator Mishimoto Performance Low Temperature Thermostat MRG Sports Racing Flywheel Royal Purple Oil Filter Royal Purple Synthetic Lubricant Package Mishimoto Liquid Chill Coolant Additive J-Tech T5 Pump X Motorsports Traction Control Suprec X-2 Block Enjin VX10 Throttle Body Blowfish FI Low Compression Pistons X Motorsports Pro Race Valves Tokiya Titanium Muffler J-Tech Fuel Pressure Regulator Formuline Air/Fuel Controller MNK Racing Spark Plug Cables DaBest Iridium Plugs FlowForce FF-K Head Netron Oil Pump FireShield Racing Thermo Wrap Tespo 800cc Extra-Flow Injectors Takayami T-X3 Intake System 85mm Jetsun XD-1 Air Filter Power Works Nagoya Stage 3 Camshafts Suprec XV4 Crankshaft Takayami Super-Flo Intake Manifold TRM RS-Ti Titanium Piping 3.75" J-Tech D90 Down Pipe Blowfish E95 Turbo Exhaust Manifold J-Tech Tech-80 42 PSI Turbo Axe Racing High Flow Fuel Rail Formuline 250 Shot Nitrous Jets BigBoss Pro Series Cam Gears Monarch Drag Cat. 4.25" Blowfish H90 Super Intercooler Power Works Nagoya RS-Plus Turbo Piping TRM Carbon Fiber Battery MRG Sports Metal Head Gasket Autorock Super Lightweight Axle Set Formuline Single 10lb Carbon Fiber Bottle Skoei Type-7 Connecting Rods Enjin High RPM spring set X Motorsports Heavy Duty Clutch Kit Zintek ECU Chip SF5 F22C (Engine) ![]() Ratios (Thanks to JV, I worked these from his Ratios) >>> ![]() PT Run >>> - Clutch Left Alone - Change @ Redline / 8000rpm ![]() |
#2 |
That was actually a lag run though Best no lag was 7.058 or 7.059 so far
#3 |
I haven't raced S2k's since like January, won't a CF top help?
And if I add a ichi cam will I be able to hit 7.04x's easier? |
#4 |
#5 |
S2k is a very hard car to drive is very inconsistent....
#6 | |
Guide
Location: New York Guided:10.18.2012 Guided:7.8.2013 . .
Ichi Bottles do not help sir. They are heavy and they ruin the redline at the end. |
#7 |
its not too bad after you use it a lot. The main inconsistency i get with it (and all my other cars) is just random times i login, go to PT and just run awful in all my cars...i can usually try again a few hours later and be fine though.
« Previous Thread | Next Thread »
| Thread Tools | |
| Display Modes | |
Hybrid Mode
