#1 | |||
Hey guys, if you're experiencing invalids read below.
To start, what are your specs? I run fine with: Dual-Core, E5200 @ 2.50GHz, and 3.24GB RAM. Of course this is an above average computer. I got it made by a friend and only cost me about $500. It could could you more for the same thing at other places. I have found that if you run a dual core, about 1.50GHz, and about 1 gig of RAM, you should run descently. Of course I'd say these are minimum specs. If you have something below these specs, consider upgrading to something a little better. I'd recommend a desktop instead of a laptop because laptops aren't built for performance so they won't run Nitto as well. Here are some things you could try before upgrading your system:
Step: 1 -Right click on your desktop and select properties. ![]() Step: 2 -On the Themes tab, select Windows Classic. ![]() Step: 3 -Click apply. ![]() Step: 4 -Head on over to the Settings tab. ![]() Step: 5 -Find the Color Quality section. ![]() Step: 6 -Change the color quality to 16 bit and click apply. ![]() Programs You Can Download: There are many programs that can help you run smoother. Auslogics Disk Defrag: Here is my personal favorite, Auslogics Disk Defrag. You see, disk fragmentation causes PC slow downs, crashes, freeze ups, etc. Auslogics' Disk Defrag is the best around and it will speed up your computer and eliminate crashes by of course, defragmenting your system. Here's the link to the download: http://www.auslogics.com/en/software...efrag/download CCleaner: CCleaner is awesome and works well with Auslogics Disk Defrag. It removes unused junk files from your system, allowing it (Windows) to run faster and freeing up valuable hard disk space. It also cleans traces of your online activities such as your Internet history. Additionally it contains a fully featured registry cleaner. But the best part is that it's fast (normally taking less than a second to run) and contains NO Spyware or Adware! Look at what CCleaner can remove! Internet Explorer - Temporary File Cache. - URL History. - Cookies. - Hidden Index.dat files. - Last download file location. Firefox - Temporary File Cache. - URL History. - Cookies. - Download manager. Recycle Bin Clipboard Windows Temporary files Windows Log files. Recent Documents (on the Start Menu). Run history (on the Start Menu). Windows XP Search Assistant history. Windows XP old Prefetch data. Windows memory dumps after crashes. Chkdsk file fragments. Apart from these CCleaner also cleans old, useless junk files from Firefox, Opera, Media Player, eMule, Kazaa, Google Toolbar, Netscape, Office XP, Nero, Adobe Acrobat, WinRAR, WinAce, WinZip and more… Here's the link to the download: http://www.ccleaner.com/download You may also be running more processes than you need. Try deleting some, but make sure you don't delete the ones you need to run properly. How do you do that? Visit www.processlibrary.com. Simply run through all of your processes and type them in exactly how you see them one by one, read their description, and delete them if they are said to be non-crucial to your system. I run all of these programs and follow these procedures atleast once a day and I run smoothly. If you can have atleast 1 gig of RAM(minimum), Dual Core Processor, 1.50 GHz(minimum), you use all the tips and tricks I offered, and you run all of those programs atleast once a day, you'll be zipping around the web in light speed and invalids and lag will be no more! Here is some more invalid/lag help from some well-respected people from the community. Thanks guys?
If you're having problems with your modem reset it or unplug it for about 20 seconds then reconnect it. If there's anything else you are having trouble with concerning lag/invalids or if you have any questions, reply here. Keep your PC clean and running smooth. D1Racer- http://nittolegends.com/communit...ad.php?t=75311 -Results may vary. Last edited by Coke Vanilla : 05-22-2009 at 09:41 AM. |
#2 |
Good job covering XP although playing in 16bit color must suck.
A couple more things: If you're on Vista there's one process that controls the smooth looking interface that you can end that's pretty bad on system resources. Its called dwm.exe. Open up Taskmanger, right click it and End Process Tree. It'll go away for a second then come right back, so do it again and it should go away until you restart your computer. When you run the test on speedtest.net, you're pinging to a server close to where you live, so your ping is going to be lower than it is to Nitto's server (unless you live in California) because it doesn't have to travel through as many routers (hops) to get there. If you want to test your ping to Nitto's server, open up Command Prompt (start>run>cmd) and type in "ping game.nittolegends.com" Also, the time it takes to ping the server doesn't really matter as much as the consistency of your pings. If you ping once and get 100ms, then again and get 400ms then you've got a problem. One cause for this would be if you're uploading or downloading anything in the background. So shut down any Peer2Peer programs (like Limewire, bitTorrent, eMule, etc) you have running cuz those will cause lag spikes when new connections come in and when a lot of people are downloading from you. And if anyone has any malware on their computers feel free to let me know and I'll help you get rid of it. I've been working with anti-malware for 4 years. If you wanna edit your post to include that that'd be cool but if not I'll just leave this reply. |
#3 |
Invalid can also caused by Low wireless Internet connection. or wireless modem not responding properly to your PC.
good post Zach. _________________________ Invalid Problems? Can't get on the game?Vista Users Only Connection Error Issues |
#4 |
u can alsow try disabeling the sound and mutting ur comp
#5 |
dude i realy got to thank u allot this helped me so much dude realy so much!!! thanx
#6 |
#7 |
Wow this is huge bro good job a milion times just wow
-Wesam |
#8 |
im on a laptop and this is my results...http://www.speedtest.net/result/421699007.png is that good or not?
#9 |
#10 |
My results are:
Download: 13893 Kb/s Upload: 5385 Kb/s Ping: 152 MS - Yet it stills invalid...=\ Any help?....I need some badly. |
