Go Back   Nitto 1320 Legends Community > Nitto 1320 Legends Car Forums > Car Brands > GM
Prev Previous Post   Next Post Next
Old 01-16-2013, 04:47 PM   #1
Dukester
Guide
Dukester's Avatar
Location: Puerto Rico Team:Revolution Racer PR Guided:10.17.12
Send a message via MSN to Dukester Send a message via Skype™ to Dukester
Thumbs up Solstice Convertible brkt 16.999 (2 gears)
OEM Front Bumper
OEM Side Skirt
OEM Rear Bumper
OEM Hood
OEM Taillights
OEM Anti-sway bars
OEM Front Seat Set
OEM Engine Mounts
OEM Race Harness
OEM Control Arms
OEM Headlights
OEM Torsion Bar
OEM Trunk and Rear Panel
Ichiban Drag Launch Kit
Nitto 1320 Drag Slicks
B Sport LM 20"
OEM Air Filter
OEM Axle Set
OEM Cam Gear Set
OEM Catalytic Converter
OEM Connecting Rod Set
OEM Crankshaft
OEM Engine Block
OEM Flywheel
OEM Fuel Pressure Regulator
OEM Fuel Pump
OEM Head Gasket
OEM Cylinder Head
OEM Fuel Injectors
OEM Intake Manifold
OEM Muffler
OEM Oil pump
OEM Exhaust Piping
OEM Valve Set
OEM Valve Spring Kit
OEM Spark Plug Cables
Mishimoto Performance Aluminum Radiator
Mishimoto Performance Low Temperature Thermostat
Mishimoto Liquid Chill Coolant Additive
Royal Purple Oil Filter
Royal Purple Synthetic Lubricant Package
Dash Platinum Spark Plug Set
TRM Carbon Fiber Battery
Enjin Low Compression Pistons -2:1
Zintek ECU Chip SF3
Formuline Air/Fuel Controller
L2 MAX 4 Cams
Dynasty Supreme Flo XR 2.5"
Zintek Z Clutch
Techoline Pro Fuel Rail
X Motorsports Big Bore Throttle Body
OEM Exhaust Manifold
X Motorsports RPM gauge with Shift Light
FireShield Racing Thermo Wrap
LE5 (Engine)
__________________
Revolution Racer PR
The real #1 Team
Dukester
Guide: 10.17.12
Written in the Stars | | Setups By: Dukester | Nitto 1320 Legends Entertainment
Si tiene algun problema o reporte envienlo aqui
Dukester is online now   Reply With Quote
